Revit MEP
Valued Contributor
lsop1409
Message 1 of 3 (133 Views)
Schedule items per floor
133 Views, 2 Replies
02-27-2014 09:05 AM
I have a building with Ground, first and second floors, each containing a number of light fittings.
How would I produce a schedule for each floor?
Is there a way to select objects to schedule, or does revit schedule all items in the project?
Valued Contributor
russellvee
Message 2 of 3 (129 Views)
Re: Schedule items per floor
02-27-2014 09:15 AM in reply to: lsop1409
Include the 'Level' field in your light fixture schedule, then under Sorting/Grouping choose sort by: level.
You can use the filter options to remove specific items from the schedule. For instance, filter for: Type Mark != 'blank'. Then set the Type Mark to 'blank' on all the fixtures you don't want to schedule.
Valued Contributor
lsop1409
Message 3 of 3 (120 Views)
02-27-2014 09:27 AM in reply to: russellvee
Thankyou
I added the Levels to my schedules and then filtered by level as you suggested and all now working fine,
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
