Revit MEP
Valued Contributor
%4seasons%
Message 1 of 2 (241 Views)
Scale Detail Item to Host Object
241 Views, 1 Replies
08-27-2013 05:49 AM
I am creating a detail item to represent the top view of the object on the host drawing. My problem is when I load the detail item to the host drawing, I cannot change the size of the detail item to match the object on the host drawing. How can I link the dimensions from the detail item to the host drawing? Any favourable response will be much appreciated.
CADastrophe
Message 2 of 2 (232 Views)
Re: Scale Detail Item to Host Object
08-27-2013 07:39 AM in reply to: %4seasons%
You would have to build the Detail Item Family with Parametric capabilities, involving Parameters and Dimensional Constraints. Once this Family is loaded into a Host Family, the value of these Parameters (the one belonging to Nested Family) can be tied to the Value of Parameter in the Host Family; Select the instance of the Nested Family and you will see a small gray button to the right of these Parameters under Properties (or Type Properties). Click on that and choose from the following list the Parameter in which to link it to.
If you need any more assistance, don't hesitate to ask!
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
