Revit MEP Forum
Sanitary Combo - Routing Preference
1 REPLY 1
826 Views, 1 Reply
How do you modify a routing preference to choose certain fittings?  We have DWV routing prefernces but they always use sanitary tees.  My preference is to use combination eighth bend wyes, I don't want to have to put them in manually.
Is there a way to choose what fitting are selected by default?  Similar to the way ACAD MEP is setup with pipeprefdef?
1 REPLY 1
abulla
If you always want your DWV system to use eighth bend wyes, change the routing preferences in the type properties of the pipe:
If you'll ever need to use a pipe type with sanitary tees again, I'd recommend creating a new pipe type that uses eighth bend wyes so you can go back to sanitary tees easily (by using Change Type) with the pipe run selected.
