Revit MEP Forum
Round & Degree Text Symbols
5 REPLIES 5
6129 Views, 5 Replies
Does anyone know how to add the symbols I mentioned in the header? It was simple in ACAD, percent percent something, I can't remember... been REVITIZED I guess.
5 REPLIES 5
CoreyDaun
Inserting symbols into Revit is a pain - you have to copy/paste or use the Keystroke, which can be found under your Character Map.
                     text in         input in
Symbol     AutoCAD         Revit
      °               %%D         ALT+0176
     Ø               %%C         ALT+0216
abulla
in reply to: CoreyDaun
I've also found that you can override dimension text (shhhhh, it's for details) by copying and pasting the ' and " symbols from the character map.
CoreyDaun
in reply to: abulla
That's great (for details). Just don't let anyone from the Architecture forum know...
I've used these symbols to do that in the past:
                          ʼ  ˮ
mmcglone
Remember that when you use the ALT codes you have to use the number pad.  The numbers on top of the letter key's won't work.
CoreyDaun
in reply to: mmcglone
AND...It doesn't matter whether or not you have Number Lock turned on - it works even if it's turned off.
