Revit MEP
davebillion
Message 1 of 2 (364 Views)
Rotating Title Block Revision Schedules: Is this possible?
364 Views, 1 Replies
10-31-2013 12:37 PM
We're finally getting into Revit and want to get the most out of the tools built into the program.
Our current standard title block has the revision data turned 90 degrees so that it's readable from the edge, along with most of our border data.
We like the idea of having revisions numbered by sheet, so we want to use the built-in revision schedule.  Problem is, we can't rotate it to go with the way we've done things.
Or, can we?  Is there a method for rotating the revision schedule?
Thank you.
Dave.
CADastrophe
Message 2 of 2 (355 Views)
Re: Rotating Title Block Revision Schedules: Is this possible?
10-31-2013 12:50 PM in reply to: davebillion
In the Title Block Family, if you select the Schedule Graphics, a pull-down should appear on the Options Bar (just below the Ribbon) which will allow you to specify a rotation.
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
