Revit MEP
Valued Contributor
Message 1 of 2 (174 Views)
Accepted Solution
Revit to use modified families automatically
174 Views, 1 Replies
11-27-2012 02:01 AM
Hi
I have modified the OOTB square to round fitting by simply deleting the flange from the round end, as it is not required. Question is, how do I get Revit to automatically use this modified fitting instead of the original one, so that I don't have to manually exchange fittings after they have been automatically drawn.
*Expert Elite*
CADastrophe
Message 2 of 2 (165 Views)
Re: Revit to use modified families automatically
11-27-2012 05:47 AM in reply to: lsop1409
The default fittings to be used are defined under Type Properties for each Duct Type. This applies to Pipe, Conduit, and Cable Tray as well.
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
