Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Revit mep 2012 default template error
3 REPLIES 3
Westechit
2779 Views, 3 Replies
This is the error I am getting is
c:programData\Autodesk\RME 2012 Templates\US Imperial\Mechanical-Default.rte
I have already tryed to do this, add content us imperial content to my revit 2012 mep software 2 times from this option below. Uninstall or change a program, select the Revit application, and click Uninstall/Change.
http://wikihelp.autodesk.com/Revit/enu/2012/Help/0000-Revit_In0/0001-Revit_In1/0017-Revit_In17/0019-...
I have also updated revit 2012 mep with the newest service pack 2 from here
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=16841348
We are using windows 7 64 bit operating system
3 REPLIES 3
CoreyDaun
in reply to: Westechit
Post this issue in the Installation & Licensing forum. It's more likely that you'll get a response there.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Lance.Coffey
in reply to: CoreyDaun
The first thing to do would be to verify if the Mechanical-Default.rte file is located in the folder specified (C:\ProgramData\Autodesk\RME 2012 Templates\US Imperial). If the file exists in the folder, verify if you can open it directly.
If the file is missing from that location, you could also try doing a Repair on the installation (through the Control Panel).
Lance Coffey
Technical Support Specialist
micro_008
i already try to repair the installation but still no default folder. i also check the folder location but no RME 2012 templates??
what is the best thing to do...
thanks and godbless
