Revit MEP
Valued Contributor
tim102289
Message 1 of 2 (560 Views)
Revit could not find a matching Pipe Segment in Default pipe type
560 Views, 1 Replies
09-20-2013 05:44 AM
Every time I try to start a pipe by clicking the connector on an air handler, I get the message:
"Revit could not find a matching Pipe Segment in Default pipe type. Please check the Default pipe type's routing preferences."
The connectors have a radius set to 1" so the pipe should come out 2".  When I click the connector however it always goes to 2 1/2" so I manually have to change it to 2".  And then once I click to place the segment of pipe, I get the message.  I've checked Segments and Sizes in the Routing Preferences and there is a 2" and 2 1/2" size both listed.  Any idea why I'm getting this error?
- Tim Smith
Motz Engineering
Revit MEP/AutoCAD/Sketchup
UC Architectural Engineering c/o 2016
"There is nothing more expensive than hiring cheap engineers." - Bob Sheeran, Xavier University 01/05/2005
*Expert Elite*
CADastrophe
Message 2 of 2 (495 Views)
Re: Revit could not find a matching Pipe Segment in Default pipe type
09-23-2013 05:36 AM in reply to: tim102289
Under Mechanical Settings » Pipe Settings » Segments and Sizes, make sure that you're looking at the sizes for the proper Pipe Segment type - make sure the value of the "Segment:" pull-down matches listed under the desired Pipe Type's Routing Preferences. Each type of Segments has it's own Size Catalog.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
You are not logged in.
Announcements
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
