Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Revit & Dialux
10 REPLIES 10
Message 1 of 11
tere_73
6581 Views, 10 Replies
Revit & Dialux
I’d like to know how to load the project and calculation result sets from Dialux (lighting software) in Revit.
We have "building design suite premium 2014".
Thanks!
Maria Teresa
10 REPLIES 10
Message 2 of 11
CoreyDaun
in reply to: tere_73
Hello Maria, and welcome to the Discussion Groups!
I am not familiar with Dialux, but to what file formats can the data be exported?
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Message 3 of 11
tere_73
Hello!
I have to import in Revit :
*.dxf files and *.stf files generated by Dialux Lighting software.
I'd like that all luminaires be in 3D format.
Is this a dream?
Thank you for your answer!
Bye
Maria Teresa
Maria Teresa Oricoli
Sezione Impianti Elettrici
[Logo Steam]
STEAM Srl
Via Venezia 59 int. 15 scala C
35131 Padova - Italia
Tel 049 8691111
Fax 049 8691199
info@steam.it
www.steam.it
Disclaimer added by CodeTwo Exchange Rules 2010
www.codetwo.com
Message 4 of 11
jernej
Hello
Anything new on importing STF file in Revit 17 ?
Plugin STF Exporter dont work in Revit 17.
https://apps.autodesk.com/RVT/en/Detail/Index?id=3774083757897632256&appLang=en&os=Win32_64
Greetings
Message 5 of 11
chris.kershaw
We changed from Dialux to Relux lighting design as it integrates into Revit a lot better. you can export a gbxml from revit to relux so no need to draw any rooms then you can export 3D lights as dwg for importing back into Revit.
But ultimately we want to to the lighting calcs within Revit its self. we have been testing Elum Tools add on, not free but so far its very good and saves a lot of time over Relux & Dialux. On test rooms we have found all 3 produce very similar results so we are about to test it on a live project.
Message 6 of 11
Hi, Have you tested Elum Tools on live project? Is it reliable?
Vaishali Patil
Electrical BIM Specialist
Message 7 of 11
I have used ElumTools on several projects the past couple of years and the results have been outstanding!! My only issue with ElumTools is that the version for Revit 2016 would randomly crash Revit and not allow you to save. The only way to solve this problem was to disable the ElumTools add-on. However, I have not had this problem when using ElumTools for Revit 2017. I love the 3D renderings of the spaces when ElumTools performs its lighting calculations.
Message 8 of 11
plomoster
Hi, maybe it's interesting to try the Relux app for Revit. Here I leave youtube link.
Greetings.
https://youtu.be/sM1ZfmKnOo0
Tags (1)
Message 9 of 11
jonathanmarsh
You can import IFC files from Revit into DIALux evo to give you the building in 3D. You cant at the moment export IFC files from DIALux evo. They are working on it and it should be coming hopefully this year. Lets see though as evo still cant do emergency lighting as a standard!!!!!!!
Message 10 of 11
NicoBro
in reply to: jonathanmarsh
You can do Emergency by doing 'direct only' calculations which wont include any of the reflectances 👍
Still not as good as the old dialux Em calculations
There's a revit Add-in to get .STF files from Revit Luminaire Hub - DIALUX tools .STF exporter
Message 11 of 11
jmin9LNC7
in reply to: gary.beauchamp
I think their rendering is not as good as or more likely "realistically comparable" to dialux's rendering yet. Dialux still produces far better realistic rendering than agi and elum tool. If you are just trying to see the technical data based rough imagery, I am sure this does not matter at all.
