Revit MEP
Message 1 of 3 (181 Views)
Revit Slowdown
181 Views, 2 Replies
08-02-2012 05:10 AM
Recently we finished a very large project. As the model grew in size the drafting of the HVAC slowed down termendously. It was so slow that connecting flex to  a grille took 4 seconds and deleteing something to 4-5 seconds. It added up over time.
I realize the file got big and I was told to reboot Revit do to its cache system. I did that everyday at lunch and it help a little.
My question: Are there any tips or tricks to make the drafting operate faster as the file grow? Any settings or hidden buttons I can click?
*Expert Elite*
CADastrophe
Message 2 of 3 (171 Views)
Re: Revit Slowdown
08-02-2012 07:08 AM in reply to: CADFLL
Check Manage tab » Warnings. A staggering amount of warning can bog the project down. There have been posts addressing this issue in recent history, and I would suggest searching this forum for those threads.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Valued Contributor
Sandleaz
Message 3 of 3 (146 Views)
Re: Revit Slowdown
08-03-2012 02:12 AM in reply to: CADFLL
That problem could have been avoided completely if your mechanical revit users started with multiple smaller, more manageable REVIT files instead of 1 file.  It's easy linking the files together.  It's hard working in a giant slow file.  The convenience of having one file will wear off as it gets larger and larger and REVIT runs slower and slower.  The trade off is simple: (A) short term convenience + major problems later on vs. (B) some adjusting and more setting up early on + no problems later on.  I choose (B) every time.
Suggestion: turn off all the pipe and duct flow and pressure calculations.
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
