Revit MEP
Valued Contributor
Message 1 of 2 (381 Views)
Revit MEP question (Low Voltage Systems)
381 Views, 1 Replies
02-08-2013 06:10 AM
Hi there:
Does anyone has a good info about Revit MEP System? I'm talking about "Low Voltage ONLY" I have a 4 floor building where the owner wants the Security System on REVIT. (CCTV, Voice and DATA, CATV, Card Reader for Doors... and so on)...
I have the book "Mastering Revit MEP" but it has not much info about it...
Please help me!!!!
Thank you so much for your help...
*Expert Elite*
CADastrophe
Message 2 of 2 (365 Views)
Re: Revit MEP question
02-08-2013 07:45 AM in reply to: jdiaz
I haven't really delved into this matter deeply, but Revit really doesn't have such Systems. I believe that you would be able to create Panels and Circuits for these Systems, but I don't think there would be a significant amount of intelligence behind it. The majority of you data would stem from Shared or Project Parameters and manual input.
The deepest I've gone into this is a task I had to total the number of data and fire alarm wires running through a Cable Tray System. Unfortunately, since Conduit and Cable Trays do not contain any actual electrical data, I had to improvise. My method is a little complicated so I won't explain it now.
A lot depends on exactly how detailed you need to be with this. If you're just creating circuits, that's pretty easy. But if you need to track wire quantities and other things like fill capacity, that's another story.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
