Revit MEP
Active Member
Message 1 of 12 (1,665 Views)
Revit MEP Pipe Sizes - How to change to less than 1"D sizes?
1665 Views, 11 Replies
10-31-2011 11:38 AM
I need to change pipe sizes to 1/2", 5/8", 3/4" or 7/8" diameter, but the program is not allowing it. 1" diameter is the smallest pipe you can change to in Properties. Does anyone know a way to do this?
CADastrophe
Message 2 of 12 (1,649 Views)
Re: Revit MEP Pipe Sizes - How to change to less than 1"D sizes?
10-31-2011 12:05 PM in reply to: PMA3333
1/2" and 3/4" sizes should be included by default, at least with RMEP 2012. Verify under Manage Tab » Mechanical Settings » Pipe Settings » Sizes. Ensure that the "Used in Size Lists" box is checked.
Active Member
Message 3 of 12 (1,643 Views)
10-31-2011 04:26 PM in reply to: CADastrophe
Thanks for the Reply. I did what you suggested but the problem persists. When I draw my Copper Pipes the results are the same. The pipes sizes start at 1" and will not allow me to select or enter a size lower than that. It also will not allow me to enter a fraction even when accompanied by a whole number. Is there another setting that I am missing?
Valued Contributor
TonyVav
Message 4 of 12 (1,642 Views)
10-31-2011 10:47 PM in reply to: PMA3333
Check "project units" Manage>Project Units.Common>Length>Rounding>Pick a Nearest fraction of your choice. OK out of that and check if you have fraction pipe sizes.
Distinguished Mentor
Message 5 of 12 (1,626 Views)
11-01-2011 10:30 AM in reply to: CADastrophe
In addition to this, there are a few other things to remember.
You notice the pipe has some parameters under Mechanical called Material, connection type and class.
MAKE SURE the new size you are adding to copper matches the same connection type and class.
"It's hardware that makes a machine fast. It's software that makes a fast machine slow."
Active Member
Message 6 of 12 (1,626 Views)
11-01-2011 11:57 AM in reply to: TonyVav
THANKS!!! That solved the problem.
Active Member
Message 7 of 12 (1,617 Views)
11-01-2011 11:59 AM in reply to: CADastrophe
Thanks! For your imput. The information you provided will help in my setup & template.
Active Member
Message 8 of 12 (1,619 Views)
11-01-2011 12:01 PM in reply to: Jrobker
Thanks for your input.
Message 9 of 12 (1,609 Views)
11-01-2011 02:23 PM in reply to: PMA3333
Your welcome
New Member
Message 10 of 12 (1,111 Views)
10-16-2012 08:44 AM in reply to: Jrobker
Thanks for your reply.
How do I check that "the new size you are adding to copper matches the same connection type and class."
Thanks in advance.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
