Revit MEP
Message 1 of 9 (387 Views)
Revit MEP - Load information not displaying correctly in panelboard schedules
387 Views, 8 Replies
07-11-2013 09:16 AM
First of all, my receptacle and lighting loads are displaying correctly in the panelboard schedules.  I have connected load phases a,b,c and then total load to tally up.  However, the loads are being displayed in total load in phase a,b,c but the mechanical load is not being calculated for some reason.  Here is a picture for reference:
At first i thought it was the panelboard schedule and the panel, but i connected the load to another panelboard and the problem followed.
Message 2 of 9 (383 Views)
Re: Revit MEP - Load information not displaying correctly in panelboard schedule
07-11-2013 09:21 AM in reply to: uabeng
BTW, I'm using Revit 2014.
CADastrophe
Message 3 of 9 (374 Views)
07-11-2013 09:55 AM in reply to: uabeng
I'm not able to reproduce this. Can you try to recreate this as a small sample in a new Project and post it here?
Message 4 of 9 (370 Views)
07-11-2013 10:04 AM in reply to: CADastrophe
Hmm I have a sample project made just now, and I recreated it on my end but its saying the file is too large.
CADastrophe
Message 5 of 9 (364 Views)
07-11-2013 10:24 AM in reply to: uabeng
Try using the Purge Unused command and then manually remove the unused Pipe and Duct Fitting from the Project via the Project Browser. If the file is still not small enough, I'll send you a Private Message with my email address.
CADastrophe
Message 6 of 9 (355 Views)
07-11-2013 11:31 AM in reply to: uabeng
I've received your file via email. So you've got a disconnect switch family acting as the load in lieu of the actual Mechanical Equipment. This is fine and all, I was just spelling out the scenario for anyone else who winds up here.
The issue here is that your disconnect switch family is set to "Switchboard" Part Type. This error will, in fact, occur if you have the Part Type set to anything except Equipment Switch, in which case it will work as intended.
You can change the Family's Part Type by opening the Family and going to Family Category and Parameters (on the Create or Modify tabs on the Ribbon) which is the icon with the tiny manila folder. At the bottom of the following dialog, you'll find a pull-down to define the Part Type. Upon loading it back into the Project and opting to overwrite, you'll see a warning message about load that are not displayed in the panel schedule.
Message 7 of 9 (352 Views)
07-11-2013 11:35 AM in reply to: CADastrophe
Oh man do I feel dumb... Thanks Corey... I've been beating myself up over this for about an hour.  I was thinking the whole time it was in the PB schedules and connector element...
CADastrophe
Message 8 of 9 (344 Views)
07-11-2013 12:03 PM in reply to: uabeng
There's a quote I've seen around here before, "Sometimes, the answer is so clear that you see right through it."
...And welcome to the Discussion Groups, by the way.
Message 9 of 9 (340 Views)
07-11-2013 12:16 PM in reply to: CADastrophe
Thanks, I've been lurking for a while but never really needed to post.
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
