I have two Revit Mep files. One called BASE MODEL which has all the mechanical systems modeled. The second¨called CONTROL MODEL has sheets, views and the BASE MODEL linked into it.
In my CONTROL MODEL views, I want to show the BASE MODEL crossing ducts pipes with hidden lines. Even though I activated the Hidden Lines option from the MEP Settings the crossing ducts and pipes from the linked Base Model are not showing properly. I opened the Base Model and crossing pipes and ducts do show correctly there. I also tried modeling two crossing ducts in the CONTROL MODEL and they also look correct.
Can anyone help me with this? It seems to be a problem on linked files...
