Does anyone have any experience with assembly codes in Revit MEP? I talked to our Revit MEP trainer and discovered that unlike Revit Arch and Building, MEP content from Autodesk does not have assembly codes assigned to them.
This issue came up when a contractor used a Revit model that we produced for cost estimation and the output was a spreadsheet that categorized building components by assembly code. For example, all of the exterior doors were under one section, etc. and I found out that ALL of the MEP content was grouped under "Misc" because they had no assembly codes assigned to them. Are all contractors/clients using Revit models for this purpose? Also, has anyone else assigned assembly codes to Revit MEP content?
