Revit MEP Forum
Revit MEP 2014 Update Release 1 won't install
2 REPLIES 2
s.lawrence
1022 Views, 2 Replies
Hi All,
I am trying to install the Revit MEP 2014 Update Release 1, but when I double click the .exe file I get the warning:
'The update release could not be installed because the expected Autodesk product could not be located on your computer. Make sure that you are using the correct update release for the product'.
I have Revit MEP 2014 (part of the Building Design Suite Premium 2014) on a 64bit machine. I've checked and I am downloading the 64bit update. It is installed in the default location on the C:\
I have logged on as Administrator and have disabled the Trend virus security, as this gave me problems when installing the program in the first place. Has anyone encountered this before?
Thanks in advance,
Stu
2 REPLIES 2
DarrenP
in reply to: s.lawrence
Thanks in advance,
Stu
There you go your not running revit mep 2014 your running revit 2014 there is a difference
you need to install this update Revit 2014 Update 1
DarrenP
s.lawrence
in reply to: DarrenP
Wonderful, thanks a lot!
Stu
