Revit MEP Forum
Revit MEP 2013 Cannot Export Anything
5 REPLIES 5
rereese
502 Views, 5 Replies
My revit mep 13 will not let me export to dwg, dwf, dxf, nothing.  I've tired them all and in all different formats and it wont export.  It does a quick think and then stop and nothing is saved.  It works just fine on plenty of other pcs in my office but not mine.  Please help.  Does it with all projects.  I have even tried repairing and reinstalling revit.
5 REPLIES 5
CoreyDaun
in reply to: rereese
This may be attributable to insufficient memory. I believe I've seen Revit do this on one of our poorer machine some time ago.
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
rereese
in reply to: CoreyDaun
well im running an 8 core 32 gb of ram (only 7gb used with revit and cad running)  and several TB of disk space.  So i dont think that would be it.
CoreyDaun
That's the only time I've ever seen Revit behave like that; refusing to operate without providing any kind of error message. The only other suggestion I can provide at the moment is to open a Project, try to export, and then attached the Journal File from that session here in the event an Autodesk support team member sees this. You should be able to locate the Journal File here:
C:\Users\[username]\AppData\Local\Autodesk\Revit\Autodesk Revit MEP 2013\Journals
I'm sorry I couldn't be of more help.
rereese
Ok thanks.
Heres the log.
I read this real quickly.. dont have time to go through in detail right now.
Sounds like  i may have to unistall and delete everything and try starting over with Revit from scratch, IDK.
' 0:< DBG_INFO: The item {[Demolished][][-1]} cannot be found in built-in export layer table. specialMap_Data[] is not consistent with Map_Data[] defined in ExportLayerStandard.h!: line 1357 of n:\build\2013_ship_x64_inst_20120221_2030\source\revit\revitdb\importexport\DBDrawingExport.cpp.
' 0:< ::20:: Delta VM: Avail +11 -> 8386430 MB, Used +1 -> 979 MB; RAM: Avail -12 -> 26523 MB, Used +2 -> 1057 MB
' 0:< DBG_INFO: Loading IntfDWG library fails.: line 72 of N:\build\2013_Ship_x64_Inst_20120221_2030\Source\Foundation\Utility\Managers\OptionalFunctionalityManager.h.
' 0:< DBG_WARN: Create Exporter Fail! It may be caused by failed to install stub installer, please check it!: line 4983 of n:\build\2013_ship_x64_inst_20120221_2030\source\revit\revitdb\importexport\DBDrawingExport.cpp.
john.lipp
Hi rereese
From the build stated in the journal, you are running build 20120221_2030(x64) which would be Revit without any updates installed.  Please try downloading and installing update release 2:
http://revitclinic.typepad.com/my_weblog/2012/10/update-release-2-available-for-revit-2013-products-...
If the issue remains, please try a clean uninstall/reinstall of Revit:
2013: How to Complete a Clean Install [Uninstall] of Revit products
 - http://usa.autodesk.com/getdoc/id=TS18782231
After installing install update release 2 again.
Then try opening one of the sample projects under the following folder and exporting to check if it is file specific:
C:\Program Files\Autodesk\Revit MEP 2013\Program\Samples
Best regards
John Lipp
Support Specialist
Product Support
Autodesk, Inc.
