Hi, I'm using Revit 2012. Is it possible for Revit to produce system curves? IE for a duct system to show CFM vs Static Pressure or for a piping system to show Velocity vs Pressure? I know the calculations are in there, I just dont know if there is a way to extract the information to Excel or to create analysis charts. Thanks.
Andy
Solved by Chris.Aquino. Go to Solution.
I don't think Revit is capable of any more than spewing out data in the form of numbers and values in a schedule. You can export the schedule data to Microsoft Excel in a round-about way. Export to delimited .txt file and then import into Excel.
CADastrophe is correct at this time, Revit cannot create charts or graphs, and the workflow would be to export the Revit database to Excel, then create the documentation there.
If you would like this functionality to Revit, this link is setup for you to submit feature requests, or feedback, directly to our Development group.
I encourage you to use the feedback link as our Development group is always interested and would like to hear your feedback directly, since you are better suited to state the business case for a feature request.
