Does anyone know how to recover a file that popes up the message attached or know what has happend or how I can open the file. I know its asy unrecoverable but is there any other way maybe to open it? Any Ideas on what I can do? I have already try restoring backup and auditing the file and the same messsage appears and I have also tried later versions of Revit, this file is a 2013 version. Have a project due close of business today if I can get a idea that would be great. Thanks all!
Solved by rbm8308. Go to Solution.
I know it's late, but I think the best course or action here would be to open a Support Case, which can be done from the Subscription Center on Autodesk.com.
Do to the nature of that error, the file may be corrupted and in need of repair. You should recover by either taking a working local file and creating a new central out of it, or recovering directly from a backup folder.
Recovering non-workshared:
If either creating a new central form local or recovering from backups are not possible please let me know. I may need to contact you directly to attempt a repair of the file.
I have the same problem and have seen this error message multiple times, with multiple files and projects. It tends to happen either first thing in the morning when I open the first file for the day, or after I have re-opened Revit at some point after closing. Other than when I have started a fresh Revit session, I rarely if ever see it, and it doesn't happen every time, but often enough to be quite annoying. I think it may have something to do with my graphics card, because I am the only one in the office that has it happen, and I think my graphics card is unique here. Our IT people were not able to figure out what was causing this. Can you help?
