Revit MEP Forum
Revit 2014 Update Issue
2 REPLIES 2
barryclark75
687 Views, 2 Replies
Hello all.
I originally installed Revit MEP 2013 from disk and updated to 2014 over the web. I tried to install Update 1 and it asked for RME2014.msi. I don't believe I have this anywhere.
Any thoughts?
Thanks!
2 REPLIES 2
TravisNave
in reply to: barryclark75
You probably will need to redownload the product if you didn't save your original 2014 download.  Many times, the service packs require the original installation source as well.
You can download it again from your Subscription Center, or you can download it from Matt, the virtual assistant.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21889745&linkID=9240617
Good Luck!
Autodesk Forums:
in reply to: TravisNave
Thanks for the reply.
I have the install downloaded to my desktop but the update still doesn't happen.
(this is still Barry despite what my Vistor name says)
