Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Revit 2014 Linked Architects File Problems
1 REPLY 1
395 Views, 1 Reply
Im using revit 2014 and i have two linked revit files into my project. One is an architects model and the other is a structural model. Both are on the companys server in the same folder. When i open the project in the morning revit loses the path to the architects model and it needs 'reloading from'. Has anyone else had a similar problem? I have tried with both relative and absolute paths and get the same issue. The linked CAD files also seem to move?
1 REPLY 1
CoreyDaun
Are you using Worksharing on your project? If so, is your Central File located on the same network, and is anyone else working on it?
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
