Im using revit 2014 and i have two linked revit files into my project. One is an architects model and the other is a structural model. Both are on the companys server in the same folder. When i open the project in the morning revit loses the path to the architects model and it needs 'reloading from'. Has anyone else had a similar problem? I have tried with both relative and absolute paths and get the same issue. The linked CAD files also seem to move?
Are you using Worksharing on your project? If so, is your Central File located on the same network, and is anyone else working on it?
