Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Revision Clouds not showing up
2 REPLIES 2
thombrady
560 Views, 2 Replies
I have created a cloud in a view at a matchline & it is not showing up in my other view although they are dependant. Any ideas why this may be happening?
2 REPLIES 2
CoreyDaun
in reply to: thombrady
Assuming that "Annotation Crop" is enabled under the View's Properties, it is likely that a portion of the bubble may be extending past the Annotative Crop Region. Select the Crop Region and adjust the outer boundary so that it contains the entire Revision Cloud.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
thombrady
As usual you the Man Cadastrophe!!
