Revit MEP Forum
Renaming shared parameters
5 REPLIES 5
913 Views, 5 Replies
Hello all,
I was curious if there was any way to rename a shared parameter through API? Any help will be appreciated.
5 REPLIES 5
Check out "RevitTV Shared Parameter Manager for Autodesk Revit" from Revittv.com, does exactly what you want
We have the code wrote to do this, but when we try to execute the program, we get an error that says "Cannot rename the shared parameter." How did you work around this? Any help would be appreciated. I attached a copy of the error we are getting.
Is your Shared Parameter File read only? If not I'd suggest contacting RevitTV directly - they are normally very responsive.
Thanks Simon. I will see what they have to say. Thanks again.
