Hi there, I have a region on a Generic Annotation symbol loaded into a family that is'nt displaying properly when printed, even though looks good on the preview.
Or have I made an error when creating the Family.
(attached is a screenshot of the pdf & families used)
I have updated the software drivers for the printer & pdf995.
This has only occured since installing the recent Update Release 2, and all other seeting have not been altered has anyone else had a similar issue ?
Solved by Alaaeldin_Alsahli. Go to Solution.
when the print windows open go to setup (right-bottom) then on the print setup page select raster processing and it should fix the problem
see attachement for a better visualize the solution
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Thanks for your reply - but we changed from printing in Vector mode to Raster mode in a bid to prevent 'blocky' curved lines (see attached).
Our symbol has only started looking like the original screengrab since we installed the update last week - when I originally posted this to @Autodeskhelp.
the only solution that i found is to edit your family and divide you filled region into several segements, i modified your family and it does look good now when comes to printing.
the problem is nested family with a circle filled area.
i have unistalled revit 2014 and then reinstall it with update1 and i still see the problem, i see it in 2013 also
i downgraded .net 4.5 to .net 4.0 and still no solution so i guess you need to play round your family, look at how i edited your nested family
here is a link for you if you want to put your feedback about this problem
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
i realised that is not with any regions, i think is more when it is a circle region.
