Is there any way to add two pieces of equipment to a systems.
Example is two boilers to a hot water supply system.
I can add them to the system,
but when I check the properties of the pipe off one of the boilers it will have a default system.
Therefore the filters I created to change the pipe color do not work because they are in a default system.
