Revit MEP
carriehall42
Message 1 of 3 (415 Views)
Accepted Solution
Receptacle Labels
415 Views, 2 Replies
04-27-2012 01:19 PM
Is there a way I can move the label for my receptacle so it would be out of the way for the circuiting? I may or may not need to move it with each instance and if I need to move the label, it would most likely be different on each receptacle. I would also like to rotate the text to where it would be horzontal each time. Is this possible? Currently I have the annotation for the receptacle set to "keep readable" in the family.
Carrie
*Expert Elite*
abulla
Message 2 of 3 (414 Views)
Re: Receptacle Labels
04-27-2012 01:26 PM in reply to: carriehall42
We use Tags for receptacles because of that issue, we just set it to read the Type Mark.
*Expert Elite*
CADastrophe
Message 3 of 3 (411 Views)
04-27-2012 01:43 PM in reply to: carriehall42
We have Circuit Number (and Light Fixture Type) labels embedded in our electrical families as a design aid, so we don't have to wrestle with Tags during design. These labels only appear on Detail Level: Medium, which we don't really use. Labels behave very poorly when a family is rotated or when they need to be moved, so we use Tags on the finished, or Sheet Views.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
You are not logged in.
Announcements
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
