Revit MEP
Valued Contributor
frazzlesnazzle
Message 1 of 4 (400 Views)
Rebel Structural Grid Won't Conform to "Halftone"
400 Views, 3 Replies
09-12-2013 03:34 PM
For some reason that I cannot figure out, the structural grids in the Architecural models I'm linking to our Electrical models stay dark, they don't get lighter like everything else in the Architect's model when I set the link to "Halftone".
Has anyone else had this problem?  If so, how did you resolve the problem?
I shouldn't have said "like everything else" in the sentence above because the structural grids are not alone in their rebellion, the ceiling grids also remain stubbornly dark a lot of the time.  I've had some success in the past with these by making changes to the ceiling material properties for whatever type of ceiling I'm dealing with but sometimes it just doesn't work.
So, if anyone has any insight about how to get the ceiling grids to conform to the "Halftone" setting also, I would greatly appreciate it.
Thanks in advance for any assistance offered.
CADastrophe
Message 2 of 4 (379 Views)
Re: Rebel Structural Grid Won't Conform to "Halftone"
09-13-2013 07:46 AM in reply to: frazzlesnazzle
What Discipline are is you View set to? If it is set to Electrical, then the Ceilings, Wall, and the other Architectural Categories of Elements should automatically be half-tone. The Grids, on the other hand, will remain full darkness.
So when you set the specific Revit Link to Halftone (under V/G Overrides, Revit Links tab), most of the elements from that link do appear as half-tone? If you print the View, does it look like the elements are obeying the half-tone setting on the printout?
Valued Contributor
frazzlesnazzle
Message 3 of 4 (310 Views)
09-26-2013 10:34 AM in reply to: CADastrophe
Sorry for the late response but, yes, when I check the "halftone" box in the Visibility/Graphic Overrides window, most of the background will display and print as halftone.  The only exceptions are the sttructural grid and the ceiling grids.
I have all of my views set to "Coordination".
CADastrophe
Message 4 of 4 (297 Views)
09-27-2013 05:42 AM in reply to: frazzlesnazzle
I am unable to reproduce this issue - can you try to reproduce this in a new Project? Are others users experiencing this, too?
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
