Revit MEP
Active Contributor
Message 1 of 6 (526 Views)
Accepted Solution
Raster Image Draw Order
526 Views, 5 Replies
09-11-2012 08:54 AM
I have linked in a raster image into my revit mep 2012 project overtop of the architectural model link.  When I set the draw order to background, it does not mask behind the linked file.  Is there something I am missing?
*Expert Elite*
CADastrophe
Message 2 of 6 (521 Views)
Re: Raster Image Draw Order
09-11-2012 09:13 AM in reply to: rschnureIV
Select the Raster Image and there is a parameter called "Draw Layer" under Properties. Change this to "Background".
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Active Contributor
Message 3 of 6 (519 Views)
09-11-2012 09:15 AM in reply to: CADastrophe
I did that, but it is not changing.
*Expert Elite*
CADastrophe
Message 4 of 6 (517 Views)
09-11-2012 09:19 AM in reply to: rschnureIV
Is the View's Visual Style set to Wireframe? This would prevent it from appearing as a background image.
Distinguished Contributor
smbrennan85
Message 5 of 6 (142 Views)
12-10-2013 09:42 AM in reply to: CADastrophe
I must be missing something. I'm having the same isssue.
I create a new project, and to get started quicker prior to receiving DWGs or RVT files, we want to trace the geometry to create walls so we can start inserting wall-hosted devices, then align the walls later. We usually have PDFs. Since Revit doesn't support linking/attaching PDFs, here's what I did:
  1. Open PDF with Adobe Acrobat
  2. File -> Save As JPEG
  3. Create new Revit project
  4. Open Floor Plan View
  5. Insert Image
  6. Browse for Image
  7. Scale
  8. Draw walls
As I draw the walls, I can see that they're there, and I get alignments  for corners and what not. But, once that wall segment is complete, I no longer see it. I've tried background vs foreground, wireframe vs hidden, plan view vs reflected ceiling plan ... nothing is working. Am I missing something?
Thanks in Advance,
Shawn
For product feedback, use this link:
smbrennan85
Message 6 of 6 (137 Views)
12-10-2013 09:46 AM in reply to: smbrennan85
Scratch that, I figured it out.
I had my view set to Electrical, therefore wasn't displaying.
once I changed my View's Discipline to Architectural or Coordination, I could see the walls.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
