Revit MEP Forum
.RVT default file association to open in Revit MEP viewer mode.
2 REPLIES 2
jeffkane2173
2576 Views, 2 Replies
can anyone help me with setting up rvt files to open auomatically in Revit MEP 2013 viewer mode? I would like to roll it out to an entire organization, wither through GPO or login script. Any help is much appreciated.
2 REPLIES 2
LisaDrago
in reply to: jeffkane2173
Hello and Welcome to the Discussion!
The only way I know of having Revit open as a viewer is to not have it licensed.
If you use a trial version - after 30 days it will become a viewer.
Not sure how much help that is but it is what I currently know.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
RAMasterson
Revit can be run in Viewer mode withe the /viewer swith in the shortcut props
