Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
RSACCELERATOR2013 environment variable
1 REPLY 1
914 Views, 1 Reply
Can anyone tell me where the RSACCELERATOR2013 environment variable is that i am supposed to set for client access to the Revit server accellerator?  The wiki help is not very helpful in this.  It just says to set the variable to the assigned accelerator.
1 REPLY 1
nbbjAdmn
You need to set the DOS Environment variable:
From Windows 7 > Start > Search > system environment > select Edit the System Environment Variables > Envrionment Variables (Advanced tab) > System Variables (lower section) > add the variable.
