Can anyone tell me where the RSACCELERATOR2013 environment variable is that i am supposed to set for client access to the Revit server accellerator? The wiki help is not very helpful in this. It just says to set the variable to the assigned accelerator.
You need to set the DOS Environment variable:
From Windows 7 > Start > Search > system environment > select Edit the System Environment Variables > Envrionment Variables (Advanced tab) > System Variables (lower section) > add the variable.
