Revit MEP
dtiemeyer
Message 1 of 4 (264 Views)
RMEP 2013 underlay
264 Views, 3 Replies
12-17-2012 10:58 AM
When I create a new floor plan based on a level it seems to default to turning on the underlay to the floor below. Is there a way to default this behaviour as 'off'?
-Dustin
Striving to be a WOMBAT, Waste Of Money, Brains, & Talent...
⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you!
Valued Contributor
RandMan
Message 2 of 4 (226 Views)
Re: RMEP 2013 underlay
12-18-2012 10:21 AM in reply to: dtiemeyer
When you're in the "New Floor Plan" dialog box, click on the "Edit Type" button.  You can apply a view tempalte from there.
New Member
justins
Message 3 of 4 (127 Views)
05-16-2013 01:43 PM in reply to: dtiemeyer
I'm having the same issue dtiemeyer, the underlay is showing the floor below on default.  We don't have any view templates being applied like RandMan.  But even looking at the view templates there is not an underlay properity to fix this.
Did you ever find a fix for this?
*Expert Elite*
CADastrophe
Message 4 of 4 (121 Views)
05-16-2013 02:00 PM in reply to: justins
There doesn't appear to be a way to change this default. Searching on other forums has led to a script that can change multiple Views to "No Underlay" at once, but no direct solution. I haven't really looked at this myself, but here's the link I found:
http://dp-stuff.org/revit-view-underlay-property-python-problem/
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
You are not logged in.
Announcements
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
