Revit MEP Forum
RMEP 2011 - no 'Pipe Sizing' tool when a sanitary pipe is selected
1 REPLY 1
dtiemeyer
354 Views, 1 Reply
I'm using RMEP 2011. When I select a sanitary pipe (or highlight an entire sanitary run), there is no 'Pipe Sizing Tool' in the Ribbon like there is when I select CW or other supply pipe. Is Sanitary pipe sizing support in RMEP 2011? If so, any suggestions as to where should I start looking for the problem?
My other CAD is a Cadillac and I like to Revit to the Max!
1 REPLY 1
It is not supported - probably due to using the UPC or IPC for fixture units, etc.. Sanitary systems will however add up the fixture units so a manual sizing can be done.
If my reply answers your query, please use the Accept as Solution.
Please give Kudos as appropriate to enhance the value of these forums.
Thank you!
