When browsing through windows to find RFA and RVT files, they display with a blank white icon and open the "Open With..." dialog box when I try to open them. Revit doesn't display in the program list, and browsing to Revit.exe file doesn't add it to the list.
This problem did not occur when I was using MEP 2011, only after I installed 2012. I've been opening files from within Revit since, but got sick of that today and tried doing a repair reinstall to no avail. Then completely uninstalled and reinstalled (twice) to no avail. Uninstalled and erased every single support file, family file and revit-associated file from my computer and reinstalled. Still won't even show Revit in the "Open with..." list of programs.
Does anyone have any ideas on what the problem might be and how to fix it? This is driving me insane and the next step I can think of is to format the entire computer, which is an option about as fesible as immersing it in salt water.
-Nick
Solved by Chris.Aquino. Go to Solution.
It sounds like a Windows issue. The following links have more information on ways to associate file extensions with applications:
Windows 7 - Default Programs - Associate a File Type or Protocol
Change which programs Windows uses by default
Cheers. Turns out the problem is caused by Windows registry still looking in the non-existent 2011 revit directory.
Hello, I just recently switched from 2010 to 2012 and I am having exact same issue. When I go to Start >Default Programs>Associate a file type or protocal with a program, it doesn't even list any Revit extension. Any help is appreciated. Thanks!
The solution that worked for me (cheers Chris.Aquino; life saver!) was the following:
C:\Program Files\Autodesk\Revit MEP 2010\Program\Revit.exe would be changed to
C:\Program Files\Autodesk\Revit MEP 2012\Program\Revit.exe
That should fix it.
