How do i hide mechanical piping drawin on teh floor below in a floor plan. i have checked by view range and both the bottom and view depth are set to 0 on the associated level. why is revit showing anything below the floor at all?
Solved by CoreyDaun. Go to Solution.
Hello, and welcome to the Discussion Groups!
When one creates a new Floor Plan using the 'Plan View' tools on the Ribbon, the "Underlay" for the new View is automatically set to the Level below. So, in your View under Properties, make sure that "Underlay" is set to "None".
