Hi everybody,
How do I retrieve a file created in version 2013 (trial version) in 2012 ? Is it possible, in version 2013, to save a file in an earlier version?
Thank you very much
Luc
Solved by CoreyDaun. Go to Solution.
You cannot save any Revit file as an earlier version. Could you expand on your situation a bit, maybe there's another solution. Was this an existing Revit 2012 file that was opened in 2013 or was it created in Revit 2013? If converted, was this a Project file (.rvt) or a Family file (.rfa)?
Thank you very much.
It's a little project (.RVT file) created in MEP 2013. This is a test I'm doing to see if the problems (calculation of pressure) have been corrected in MEP 2013. I would like to open the file in RVT 2012 whether I would have the same results.
Have a nice day.
Unfortunately, the method I've heard of to be able to open a Revit project in an earlier version (export/import as IFC file) would not retain your calculations. You will have to recreate it in RMEP 2012 as far as I know.
