Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
REVIT MEP 212 & 2014 Installation Error/Toolbar - can't reinstall 2012
1 REPLY 1
CADArmor
1048 Views, 1 Reply
I had Building Design Suite 2012 & 13 on my machine. I installed 2014 and then experianced problems with toolbars freezing and not updating in Revit 2012. Fr example I will select a pipe and the toolbar should automaticall update but it doesn't. To fix it I uninstalled 2012, 13 & 14. I tied to reinstall 2012 but the setup says it is installed in my computer. How can I reinstall 2012?
Someon Please help
1 REPLY 1
edwin.prakoso
in reply to: CADArmor
Revit 2012 and 2013 did not support .NET 4.5. Revit 2014 will install it as prerequisite.
However, you can install service pack and hotfix that can fix this issue.
Read more about it here:http://cad-notes.com/2013/04/revit-ribbon-is-messed-up-after-revit-2014-installed/
For the second problem, did you already uninstall Revit 2012 from program and features?
If you did and still have problem reinstalling it, try using Microsoft FixIt to uninstall it: http://support.microsoft.com/mats/program_install_and_uninstall
If this post solves your problem, please mark it as solved. It will help others with a similar problem to find a solution.
Kind regards,
Edwin Prakoso
LinkedIn | Website | Twitter
