Revit MEP
Valued Contributor
hcanas
Message 1 of 4 (277 Views)
Accepted Solution
REVIT MEP 2013 - ADD PARAMETER TO A DATA OUTLET
277 Views, 3 Replies
03-06-2014 09:16 AM
I have a DATA OUTLET tag/w a ID circuit number parameter, I need to add the floor number (parameter) at front, any idea how to do it?
Please help...
Thank you in advance.
Dave
*Expert Elite*
CADastrophe
Message 2 of 4 (262 Views)
Re: REVIT MEP 2013 - ADD PARAMETER TO A DATA OUTLET
03-06-2014 11:34 AM in reply to: hcanas
There is no automatic way to do this. The course of action that I recommend would be:
1. Create a new Shared Parameter [Text] for this prefix and add it as a Project Parameter (Electrical Fixtures, Instance).
2. Add this Shared Parameter as appropriate to your Tag Family.
3. Create an Electrical Fixtures Schedule and include "Level" and your Shared Parameters as the only fields.
4. Set the Schedule to sort by "Level". Disable "Itemize Every Instance". Hit 'OK'.
5. In the Schedule View, you can select the blank cells next to each listed Level and enter the desired value. This value will then be cascaded to all applicable Model Elements in the Project.
There is some manual labor involved, but it's not much. You must periodically return to the Schedule and reenter these values in order to apply them to all newly created Model Elements.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Valued Contributor
hcanas
Message 3 of 4 (235 Views)
03-06-2014 02:26 PM in reply to: CADastrophe
Corey D.
Thank you, for your reply.
I got lose on between 1st & 2nd steps, can you go step by step on those two ..please.
really apreciate...
Dave
Valued Contributor
hcanas
Message 4 of 4 (226 Views)
03-06-2014 02:45 PM in reply to: hcanas
Sorry, I got the answer here...about the shared parameter..
http://www.aecbytes.com/tipsandtricks/2011/issue58-revit.html
You are not logged in.
Announcements
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
