Revit MEP
CADFLL
Message 1 of 4 (505 Views)
REVIT 2012 - MEPFS CALCULATIONS
505 Views, 3 Replies
08-27-2012 11:01 AM
I am playing around with Revit 2012 and trying to make it faster (and learn). How do you shut off calculations for mechanical, plumbing and fire sprinkler?
Is it easy to do? Do some trades turn on/off easier than others?
Valued Mentor
julianjameson8403
Message 2 of 4 (479 Views)
Re: REVIT 2012 - MEPFS CALCULATIONS
08-28-2012 07:10 AM in reply to: CADFLL
Within the type properties of duct systems and pipe systems, there is a parameter called "Calculations". Here you can turn off Revit's calculation systems. However - not all pipe systems run calculations, such as the fire protection systems.
For electrical calculations, go to the electrical settings and turn off "Run calculations for loads in spaces" under Load Calculations section.
If my reply answers your query, please use the Accept as Solution.
Please give Kudos as appropriate to enhance the value of these forums.
Thank you!
CADFLL
Message 3 of 4 (477 Views)
08-28-2012 07:13 AM in reply to: julianjameson8403
Where is exactly is this? I was told FS calculations can not be shut off.
Valued Mentor
julianjameson8403
Message 4 of 4 (474 Views)
08-28-2012 07:28 AM in reply to: CADFLL
In the project browser under the Families section.
That is correct on FP calculations.
As mentioned previously, not all pipe systems perform calculations. These are the Fire Protection types and "Other" pipe types.
Thank you!
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
