Revit MEP
New Member
jbecker
Message 1 of 4 (178 Views)
Projecting Centerlines
178 Views, 3 Replies
09-14-2012 12:32 PM
All elevation views including arch views with MEP linked model are displaying pipe, duct, conduit, etc. Centerlines as if they were projecting to the outside wall. (looks like buckshot crosshairs.
I am able to turn them off centerlines in VG but that is a big effort over many views.
Any thoughts on what can be controlling this apparent projection?
Valued Mentor
julianjameson8403
Message 2 of 4 (157 Views)
Re: Projecting Centerlines
09-17-2012 02:53 AM in reply to: jbecker
How about try using view templates to control the visibility of centrelines for various elements?
The view's detail level will also affect how these display.
If my reply answers your query, please use the Accept as Solution.
Please give Kudos as appropriate to enhance the value of these forums.
Thank you!
New Member
jbecker
Message 3 of 4 (154 Views)
09-17-2012 04:15 AM in reply to: julianjameson8403
Yes, we are using view templates to correct the problem. Still a labor effort. Thanks.
The question is why the centerline "projection" is occurring in the first place. Are there any control options for centerlines which would limit the visibility?
I do not understand why (single example) a pipe 50 feet inside the building is "projecting" its centerline thru the outside wall. The pipe does even run perpindicular to the wall. It is a open end pipe not yet connected to anything else.
Any additional thoughts would be appreciated.
Product Support
Chris.Aquino
Message 4 of 4 (131 Views)
09-18-2012 07:00 AM in reply to: jbecker
I would check the depth of the elevation to make sure the pipes that are showing are not in it. I would also check to see if depth clipping is on or off.
Chris Aquino
Technical Support Specialist
Customer Service & Support
The Revit Clinic
@Revitclinic
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
