Revit MEP Forum
Problems Trying to configure LMTOOLS
8 REPLIES 8
Message 1 of 9
reLLKs
866 Views, 8 Replies
maybe anyone can help i havep orblems configuring my lmtools, i give him a license file... it starts server normaly ... but while checking server status it's like diagnostic i have such error as "adskflex: The desired vendor daemon is down.
Check the lmgrd log file, or try lmreread." and "FLEXnet Licensing error:-97,121" I'm runnig "FLEXnet Licensing v11.4.0.0 build 31341 (lmgr.lib), Copyright (c) 1988-2006 Macrovision Europe Ltd. and/or Macrovision Corporation. All Rights Reserved."
8 REPLIES 8
Message 2 of 9
ptodorov
in reply to: reLLKs
some quick netes:
1. Check firewalls (disable them)
2. Check ports (network license works on a serten port is it free)
3. Are you have admin privileges when you set up lmtools (it is a must)
4. Check out for ,,dumb" antivirus software that have firewalls (like NOD 32) - disable them
Message 3 of 9
reLLKs
in reply to: reLLKs
Well... it seems i'm having problems with my 23 port ... it should be opend i i want program top work... but as i tried it's just won't open... and my firewall is off 🙂 i wrote manualy to open prot 23 but still it's closed.. i checked it with ip tool
Message 4 of 9
reLLKs
in reply to: reLLKs
Myabe someone knows wht prots should be opened for LMTOOLS to work properly
Message 5 of 9
ptodorov
in reply to: reLLKs
http://discussion.autodesk.com/thread.jspa?messageID=5447922
Hire is similar problem. Check it.
Message 6 of 9
reLLKs
in reply to: reLLKs
Now i'm totaly confused... i was reading my log file and it says:
_________________________________________________
8:47:37 (adskflex) License server system started on Turbo
8:47:37 (adskflex) No features to serve, exiting
8:47:40 (lmgrd) adskflex exited with status 27 (No features to serve)
8:47:40 (lmgrd) adskflex daemon found no features. Please correct
8:47:40 (lmgrd) license file and re-start daemons.
8:47:40 (lmgrd)
8:47:40 (lmgrd) This may be due to the fact that you are using
8:47:40 (lmgrd) a different license file from the one you expect.
8:47:40 (lmgrd) Check to make sure that:
8:47:40 (lmgrd) C:\Program Files\Autodesk Network License Manager\License\REVSYP2008Turbo.lic
8:47:40 (lmgrd) is the license file you want to use.
8:47:40 (lmgrd)
But how can this be... i recieved this file from Autodesk activation ..... i specified host name and host id perfectly.. i'm getting really angry with getting this ===> FLEXnet Licensing error:-97,121 ... my compony bought this revit and we can't use it... and projects are stopped....... this is insanity .....
Message 7 of 9
ptodorov
in reply to: reLLKs
1. Are you change host name (computer name) of the computer (preinstaling windows)?
2. Are you change MAC address of lan card (change lan card)?
Message 8 of 9
reLLKs
in reply to: reLLKs
noup... computer name is the same.. i haven't reinstalled computer for 8 month... i've got this lecense file 2 days ago from the same computer... mac adresse is the same.. i checked it myself... it's the same as i got in licese achievment programs as in cmd, they are the same, and they haven't change for a long time.... that's really getting me nervious 😕
Message 9 of 9
IAtika
in reply to: reLLKs
someone ever solved this issue ? .... i am having the same problem
Rail Community
