Revit MEP Forum
Problem with Spot Elevation
6 REPLIES 6
max.a.hollander
1199 Views, 6 Replies
I have having trouble taging mechanical equipment with the spot elevation tag.  Its been working on my ducts and pipes but not on the heat pump water source component.  i want to put a spot elevation for the bottom of the equpiment.
6 REPLIES 6
CoreyDaun
in reply to: max.a.hollander
The Spot Tag cannot tag an element that is represented by Symbolic or Model Lines alone. That is, if all of the 3D elements (extrusions) in the family are not visible, the Spot Tag cannot target it.
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Tags (1)
I understand that the issue is that it only is happening in the file that im working in.
i created a new file with nothin in it to test if it is the component.  i placed the same mech equip componet i have in my file and was able to spot elevation bottom of equip in the new file.  the spot elevation workd fine everywhere else but this one component and works on that saem component in a diffent file but mine.
CoreyDaun
Could you post the Family as an attachment? I'm not having luck recreating the situation.
max.a.hollander
in reply to: CoreyDaun
So ive realized that this water source pump is not the one that we will be useing for this building bc we found a cheaper one. and the new water source pump spot elevates fine. id still like to know why it wasnt working in the subbasement lvl.
CoreyDaun
The problem is that the extrusions within the family are set to be invisible in Plan View, and are instead represented by Symbolic Lines. See below...
max.a.hollander
Thank you very much
