I have a problem in the printout from Revit MEP 2012. All the walls in floor plan appear very light (grey color) where the rest of the drawing including text and dimensioning shows dark in color (black).
Can anyone help me with this issue so that I can have my entire printout in black color...please....Very urgent.
Phani.
In the Print Dialog, go to "Setup..." and try setting 'Colors:' to "Black Lines" and selecting the option: "Replace Halftone with Thin Lines".
The architectural elements are being Halftoned because your View's Discipline is likely Mechanical or Electrical. If the lines are still too light, you can give those Categories a darker lineweight or you can adjust the Halftone/Underlay Settings, which is found under Manage tab » Additional Settings.
