Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Pressure drop calculation / system inspector
3 REPLIES 3
bcpratt
776 Views, 3 Replies
I've been able to successfully generate a pressure drop report for a few systems in my project.  I have an exhaust system that appears to be well-connected, but after running the pressure drop calculator have found that a negative airflow(?) has crept into the system for some reason.  Why would this happen?  It is a fairly simple exhaust system with two grilles, ductwork, an exhaust fan and a louver.
Thanks.
3 REPLIES 3
Chris.Aquino
in reply to: bcpratt
To give the community a better idea of what you are seeing, please post a stripped down sample file showing this behavior.
Chris Aquino
Adoption Marketing Manager | BIM Collaborate Pro
@Aquinotecture
billy.barrios
Perhaps you might have to check you're equipment connections and make sure they're set to bi-directional. That might fix it.
scott_dakin2
One of the connectors will be working in the wrong direction.
