Revit MEP
Member
miguelvalencia5598
Message 1 of 3 (213 Views)
Pressure Loss Report Location
213 Views, 2 Replies
09-11-2012 01:21 PM
Is there a way to change the default out put location of the "PressureLossReportFormats.xml" that is generated by Revit when creating a Pressure Loss Report?
According to Autodesk WikiHelp, it is .."saved in the same location as the default template." The problem is that our default template location is on the network w/ read-only access, thus creating an error everytime we try to create a report.
Miguel
New Member
Message 2 of 3 (148 Views)
Re: Pressure Loss Report Location
09-27-2012 01:47 PM in reply to: miguelvalencia5598
We are having this same issue.  Does anyone have a fix for this?
~Brett
Member
miguelvalencia5598
Message 3 of 3 (146 Views)
09-27-2012 01:51 PM in reply to: brg34
We figured it out. It is controlled thru the INI under:
[Directories]
DefaultTemplate= <Location of template file>
Since the PressureLossReportFormats.xml needs constant read/write access and in order not to have many users save back to it (overwritting the PressureLossReportFormats.xml) by adding their own custom formats, we decided it was best to keep it under each users C: drive rather than on the network. This will keep the .xml file clean.
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
