I have a hi & low floor plan (All are level 1) where I need to show the duct & steel. I did the low area no problem with the view range but when I did a plan region around the high area I see either the steel & fittings with no duct or the duct & fittings but no steel. I played with this for an hour with multiple adjustments & just could not get it quite right. ANY IDEAS what I may be doing wrong? I have heard in the past that Plan regions have not worked well.
Plan regions are useless in MEP, they have never and still do not work.
Just create a new level and views from that if you need.
Thanks, from what I have been reading that seems to ring true about Plan regions.A great idea in concept if it would work like a true view range. I may have to do a workaround like a lot of things in REVIT.
