I am revit MEP beginner. I tried to place electrical panel on the drawing, everything is fine, my panel is put on vertical face, but on the panel it shows a question mark?
What is this for?
Thanks!
Solved by julianjameson8403. Go to Solution.
That is most likely the tag for the panel name. It is a question mark as it has no value at the moment. When placing equipment you can tag when placing - the option is shown on the ribbon.
Yes, it is the tag for the panel, now I know how tag it, thank you julianjameson8403!
