Revit MEP Forum
Piping Systems Revit 2012
1 REPLY 1
611 Views, 1 Reply
How are plumbing piping systems suppose to work in Revit 2012?  It seems there are various opinions, wants, needs, approaches.  Here is my experience....
My current project is a hospital. The core of the hospital is a first floor only with 2 patient wings that are 2 floors - a first floor and a ground floor.  Our mains are routed throughout the hospital only on the first floor.  We route down from the first floor into each patient room on the ground floor.
Each patient room consists of a water closet, 2 lavatories, and a shower.  One wing has 15 patient rooms the other wing has 16 patient rooms.  That's a total of 248 plumbing fixtures in the patient rooms alone.  That's a lot of plumbing fixtures to connect to one system.  That's not even counting the break rooms and other specialty rooms per wing, nor is it counting the core of the hospital.
In my test I piped each patient room individually without connecting to the mains and named the system in relation to the patient room number they are feeding.  Example, Pat Room 1025 has 2 systems, CWater 1025 and HWater 1025.  These show up in the system browser under their respective system type.
Piping=>
   Domestic Cold Water=>
      CWater 1025=>
         Fixture 1
         Fixture 2
      HWater 1025=>
         Fixture 1
         Fixture 2
With all the rooms piped up individually, ready to connect to the mains, my production speed is tolerable.
I then start connecting each branch pipe into the main and as I go around each patient wing making these connections I watch each individual system disappear and get added to one single system.  After all the branch piping is connected I end up with only one system.  It's usually the system I use to make my first connection.  So if I use CWater/HWater 1025 to make the first connection to the mains, all systems thereafter become CWater/HWater 1025.
The problem I have after this is that my production speed falls into quick sand, it now takes more than twice the amount of time to connect a pipe and or delete a connected pipe.  It can take upwards of 10 secs just to add a little 1/2" tap off that's 2' long, and god forbid if you misclick due to the slowness, then it's another 10 secs just to undo the mistake and another 10 secs to make the tap again.
The other route that I attempted was to create a new Piping System under "Families" in the Project Browser.  I can create a new Piping System for each patient room but that is extremely inefficient.  So either I'm doing something wrong or my expectations of Revit are way to high.
I'm not interested in creating separate models for different systems and my computer is more than adequate to run Revit.
Is anyone else experiencing the extreme "lag" of Revit after adding a numerous amount of fixtures to a system ?
Why can't I easily keep systems separate to reduce this "lag" ?
1 REPLY 1
fkleiner
Brian, I expect that the lag you are talking about is due to calculations on the piping. If you are using calculations then it is expected that a large model will lag. If you do not need them, I suggest you turn them off in your Piping Systems in the Project Browser. For your working views you can create worksets, perhaps for different rooms and areas, so that way you can "unload" the worksets you do not need to see.
I too am interested in the correct way to achieve what Brian is looking for. Fortunately, we have not yet started a Revit project the size of what Brian is talking about, but that is next in the pipeline.
