Revit MEP
Active Member
Message 1 of 2 (250 Views)
Pipes showing turned down rather than up
250 Views, 1 Replies
01-15-2013 09:11 AM
I am relativly new to Revit so bare with me.
I am having a problem with how my piping is showing. I am working on sanitary pipes that are underslab, with branches coming up through the slab to the lav/water closet/shower. When I turn the pipe up, it shows that the pipe is going down. I tried adjusting the view range/cut plane and can't seem to figure it out.
Any help would be greatly appreciated
Here is a sample of my issue:
Distinguished Contributor
Message 2 of 2 (245 Views)
Re: Pipes showing turned down rather than up
01-15-2013 09:37 AM in reply to: Niamhy14
Not sure if it meets your needs, but if you put a cap on the piping, it should show "circular" up rather than the down symbol.  The reason your picture looks like that has to do with the open end of the pipe and the cut plane I believe.
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
